I'm trying to find
similar robots (or even the horizontal arm by itself - e.g. this https://www.igus.eu/product/21105?C=DE&L=en&artNr=RL-SCR-0102)
with similar specs to compare. It won't be lifting heavy loads (max. 500 g - probably only
up to 200 g) and won't need to go fast at all. It will need a pretty large
vertical range though (up to 2 m depending on the final specs of the project).
Thats why I was thinking about going with an arm like the mentioned one bolted
to a linear rail.
Does anyone have
some recommendations or maybe even some keywords with which I could find
something like this.
If you need any
additional information let me know.
If theres a similar
topic I couldn't find it. If there is I'm sorry and I'll take a link and you
can delete this :)
Hi everyone,
I'm working on a project where I need a SCARA robot where the first axis is the linear / vertical one. Like this one:
https://www.igus.eu/product/21104?C=DE&L=en&artNr=RL-SCR-0101
I'm trying to find similar robots (or even the horizontal arm by itself - e.g. this https://www.igus.eu/product/21105?C=DE&L=en&artNr=RL-SCR-0102) with similar specs to compare. It won't be lifting heavy loads (max. 500 g - probably only up to 200 g) and won't need to go fast at all. It will need a pretty large vertical range though (up to 2 m depending on the final specs of the project). Thats why I was thinking about going with an arm like the mentioned one bolted to a linear rail.
Does anyone have some recommendations or maybe even some keywords with which I could find something like this.
If you need any additional information let me know.
If theres a similar topic I couldn't find it. If there is I'm sorry and I'll take a link and you can delete this :)
Thanks in advance.
