Hi everyone,I recently noticed a significant delay of about 100ms during data transmission while testing with UR5 and FT300, which is clearly abnormal. For your reference, my system version information is as follows: URcap: 1.8.1, Firmware: FS2-1.6.3, and Driver: DFU-1.2.1.Here is the code snippet for establishing the connection. I am using a socket to establish the connection, but I am not using data streams. I am not sure why I am unable to read normal data once I start using data streams.####################################################################################class ForceSensor: def __init__(self, ip='196.168.0.111', port=63351, buffer_size=1024, pattern=re.compile(r'-?\d+\.?\d*')): self.ip = ip self.port = port self.buffer_size = buffer_size self.pattern = pattern self.sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM) self.sock.connect((self.ip, self.port)) def get_data(self): response = self.sock.recv(self.buffer_size) if response and len(response) > 0: val = response.split(b'(', 1)[1].split(b')')[0] array = [float(x) for x in self.pattern.findall(val.decode())] return array else: return None####################################################################################I tried non-blocking mode as well, but it didn't help.The method for detecting the delay is that I use the 'speedl' function to move the robotic arm for one second while continuously printing the force feedback with get_data(). I keep doing this until the motion is complete, but the difference between the console output and the values on the robot arm panel is quite significant.The following code is what I wrote based on the data stream section in the manual, but the data I received is not force feedback at all.####################################################################################def start_data_stream(sock): register_address = 410 register_value = 0x0200 sock.send(struct.pack(">HH", register_address, register_value))def stop_data_stream(sock): stop_sequence = b'\xff' * 50 sock.send(stop_sequence)def parse_data_packet(data): fmt = ">BB6h2B" _, _, *raw_data_values, _, _ = struct.unpack(fmt, data) data_values = [ raw_data_values[0] / 100.0, # Fx (N) raw_data_values[1] / 100.0, # Fy (N) raw_data_values[2] / 100.0, # Fz (N) raw_data_values[3] / 1000.0, # Mx (Nm) raw_data_values[4] / 1000.0, # My (Nm) raw_data_values[5] / 1000.0, # Mz (Nm) ] return data_valuesdef read_sensor_data(host="196.168.0.111", port=63351, num_packets=30): with socket.socket(socket.AF_INET, socket.SOCK_STREAM) as sock: sock.connect((host, port)) start_data_stream(sock) time.sleep(1) received_packets = 0 while received_packets < num_packets: data = sock.recv(16) if len(data) == 16: force_and_moment = parse_data_packet(data) print(f"Data: {force_and_moment}") received_packets += 1 stop_data_stream(sock)if __name__ == "__main__": read_sensor_data()####################################################################################Below is the data that I received.I was wondering if anyone has any suggestions or solutions to offer?
