Dear Robotiq community I'm planning on mounting a UR10 robot in the center of a 720x720x720 mm table with 8080 aluminum profiles for pick and place operation. The weight of this table would be around 50 kg and will not be bolted to the floor. Anyone experience with this type of setup to estimate whether this is sufficient to prevent the table from tumbling over or the robot moving/vibrating the table?Thank you for your time.
