Hi,I am programming a UR5e with a Robotiq 2-finger gripper. I have installed the URCap for it.On the pictures:I can set 41% manually using "edit action".But I would like to use the variable "gripper_pose" which is instantiated to 0.41 one line above in the program.It is possible?CheersSimon
Indeed the GUI does not allow to use a variable for gripper finger position.You can check page 112 of the manual (https://assets.robotiq.com/website-assets/support_documents/document/2F-85_2F-140_UR_PDF_20210623.pdf) to get all available script functions:
On the pictures:
Cheers
Simon
