When setting up the plane feature I need my grippers to be at a 45 degree angle. When I run through the plane wizard in this orientation it shows it correctly, but then turns to face straight down or straight up when I move to the position. Can anyone explain this. I adjusted the rx,ry,and rz using the edit feature after the wizard to give it the right orientation but I want to understand why it does this
Maybe you could share some screenshot of what append to make it more visual ? That could help people from the community to guide you.
