I use the actionlib to control the gripper open and close.I set the full speed of the gripper.but i still feel the speed is too slow.I would like to know there have any method to increase the gripper speed?
I would like to know how can i always get the maximum speed?i find that different gopper start position the speed also different.thanks
You should have the speed parameter at its maximum. Which means a value of 255 in the speed modbus register.I recommend that you check modbus rtu description and example of the gripper manual.What is actionlib ? Which coding language do you use ?
