Hi,When I'm running the force control on UR10, it's a continuous multiple-times force control. But there often comes out an error on the URcap : Force mode: maximum orientation/position deviation exceeded.I guess it is because of the robot's pose changing in one step is greater than the limit I set. Is this right?And also when such an error happened, the rtde_control will be automatic stopped and the subsequent force control commands will no longer take effect.So I want to know whether there is a solution to not letting this error interrupt the whole control process?I'm programming in python and controlling the robot by RTDE package.So could I use the Try-Catch function to catch the error? If it is possible, could someone offer an example?Thanks!
Is this right?
Thanks!
