Hi,When I'm running the force control on UR10, it's a continuous multiple-times force control. But there often comes out an error on the URcap : Force mode: maximum orientation/position deviation exceeded.I figure out it is because of the robot's pose changing in one step is greater than the limit I set. But when such an error happened, the rtde_control will be automatic stopped and the subsequent force control commands will no longer take effect.So I want to know whether there is a solution to not letting this error interrupt the whole control process?I'm programming in python and controlling the robot by RTDE package.Such as the code:try: print(x)except: print("An exception occurred")
bcastets said: Are you using Robotiq Copilot URCAP for the force control or UR force control functions ? I'm using the UR force control functions, but the error occurred on the URCAP with a pop-up window.
This is an error from the prepackaged force function included in Polyscope. It does not look related to a UPCAP.I am sorry that I don t have enough experience with UR force functions to explain the cause of this error.Maybe some one else from the community will be able to help.
Such as the code:
try:
print(x)
except:
