Hello, what is the best way to transform the orientation of the robot between 2 frames?I have 2 robots that I am trying to synchronize in a master-slave system, the usual position is simple but the orientation is not so obvious. I read the position of the master robot and transform it to the slave base frame. So far I have managed with the position but not with the orientation.I will be grateful for any help.Thanks a lot!
Maybe you could have a look to this article:https://dof.robotiq.com/discussion/2281/urscript-calculate-point-coordinate-from-a-custom-frame#latest
Thanks for the answer. For some reason I don't get the correct values when I use this approach. in my case:I have a new frame that only rotates around the z-axis by 254°, as far as I do:frame = [0.0, 0.0, 0.0, 0.0, 0.0, 4,43314]point_from_frame = pose_trans(pose_inv(frame),point_from_base)the values I receive do not match my expectationsI hope you can help me with it
frame = [0.0, 0.0, 0.0, 0.0, 0.0, 4.43314]and as better explanation: i need result because i have the pose2 and pose1 is the transformation between start and Ref. in my case there is no translation between Start and Ref, i have only Rotation around Z-axis by 254°. another question is representing Pose1 by [0.0, 0.0, 0.0, 0.0, 0.0, 4.43314] correct?
The formula you are using is the following:point_from_frame=pose_trans(pose_inv(frame),point_from_base)frame = [0.0, 0.0, 0.0, 0.0, 0.0, 4.43314]point_from_base= input of the functionThis will return the coordinate of "point_from_base" (expressed in base referential) in frame referential.I guess the result will be something like [x,y,z,0,0,0]
Thanks a lot!
