Hello, I have seen an article about calculating weight using get_tcp_force(), but is it possible to use the function to check for an object? I would like to move in the Z axis until a certain force is reached. How can I do that?I can't think of a way to use get_tcp_force() live in an if statement.
I'm working on a system that had a prox switch to detect a part and they used a wait command until the prox went high. The prox is no longer and I need to use force sensing. Please help
It will be same logic.Example:If continuously check get_tcp_force()<10 MoveL Distance base -Z 100mmIn our Force Copilot force we have a node call "find surface" to do that.Here below is a elearning video about it:https://elearning.robotiq.com/course/view.php?id=7§ion=7
How can I do that?
