I am occasionally seeing the following error popup coming from the Robotiq Copilot URCap. The popup suggests disabling the Ethernet/IP Adapter, but I am using that for PLC integrations that cannot be turned off.It doesn't happen often, but when it does it results in a failed process and downtime.Is there any code I can run to ensure the RTDE interface has initialized and probably handle the error if it does occur? The popup is not helpful when running the controller in remote mode using the dashboard server.
We have the same problem. We use the Force Copilot with an Schunk EGL gripper (Profinet) and this error stopps our program. The error message comes at irregular intervals.
Hi,Following up with the same issue stated above. The error message comes at irregular intervals. Is there any update / solution for this? Thanks,
bcastets said: I transfered your question to our support team. We will contact you via email. Hello, we are using Force Copilot with ur_rtde; and I am experiencing the same problem. Do you mind share the solutions? Thank you very much.
![Image: https://storage.googleapis.com/robotiq-dof-uploads/editor/er/5za4ci7lqlgq.png zoom](https://storage.googleapis.com/robotiq-dof-uploads/editor/er/5za4ci7lqlgq.png)
