@drpz
Fx, Fy and Fz are not coordinates. This is the force apply on each axis.
You can get the position of the object detected via the variable : object_location
object_location is a UR waypoint like: P[x,y,z,rx,ry,rz]
Knowing that you can get the x,y,z position.
- x=object_location[0]
- y=object_location[1]
- z=object_location[2]
I'm using Cam Locate to find an object, and would like to write the XYZ coordinates of the object to Modbus, but I'm a little unsure of the syntax. It looks like the XYZ position is stored in Fx, Fy and Fz variables, and I also see Copilot functions like "get_sensor_fx()". I have tried: Set MODBUS_3=Fx or Set MODBUS_3=get_sensor_fx(), but that isn't working. Anyone know how to do this?
I'm also curious to know if someone can explain what these coordinates are offset from, and how to find that?
Thank you!
