Instead of force()<50 you'd have to use: "get_tcp_force[2] = currentForce" in a thread. The "2" in the bracket means you only want to store the force in the Z direction as get_tcp_force returns the standard [X, Y, Z, Rx, Ry, Rz] coordinate system.
In the until expression you could then put something like currentForce < 50.
Hi community :)
Universal Robots UR-10 CB3
I'm currently using the direction command to seek downwards for obejcts.
I currently have 2 untill-expressions, one that waits for a function to become true and one that stops the direction when a distance is reached.
Is it possible to also use the force command as an untill-expression?
For an example:
Direction: Base Z-
- Untill expression Vacuum_OK=True
- Untill force()<50 N
- Untill Distance: 50mm
When i right this in my program it seems like it jumps over these 4 lines
Is this possible or is there another way around
The program has to seek downwards towards an object
- When Vacuum_OK is true it has to move up Z+
- When the Robot tool detects force it also has to move up. this is to spare the robot
- Finally the robobt must never go further than 50mm in the Z- direction
