I need some help here. I have installed a new robot onto a machine and was teaching the points. When I powered down the robot and went to go to that waypoint the base of that waypoint had moved way over! I tried this again with several different waypoints and all of them did the exact same thing. I haven't seen this problem before as I have about 8 of these robots running. Does anyone have any ideas what im missing here? Thanks.
@meeksy Could you share screenshot of the parameters of the move node and a screenshot of feature in the installation menu ?If you make waypoint relative to a feature and if the installation file is not save when you shutdown the robot, you may lose the reference feature point.In this case, I imagine that it is possible to all move node which were using this feature change to base feature.
