Here below is an example of program structure you could use to validate the input of the operator.
I have copied your program ro my CB3 but i cant really figure out what get_list_length is?bcastets said:Here below is an example of program structure you could use to validate the input of the operator.
And it gives me an error message when it gets to
If value=acitveDistances[i]
What could be wrong? or is it simply because i cant copy it to my CB3
Hi community :)
I have made a program for my UR-10 where the operator can enter different values, respectively 44, 46, 48 and 50. This input changes a distance the robot travles in the program. If the operator enters a different values, for an example 40, the robot will not do as attended. However the robot will still run the program.
I need to stop the program if the values 44, 46, 48 or 50 isnt entered at the start up of the program.
i already made an if task that says:
If travel_distance≠active_distances
-stop program
active_distances are my 4 values 44,46,48 and 50, but how do i bind them correctly to the variable.
if i where to write:
active_distances: 44 or 46 or 48 or 50 in the command task
the program stops anyway when i try to start the program with one of the values entered in the start
How can i do this? and is there a better way to do it?
- Sebastian
