My cobot won't go to the correct approach point and the patternpoint in the pallet function. I have watched a few tutorials and set everything up, but when I start the program it wont go to the correct approach point and patternpoint. It does go the correct exit which is the same as the approach point.Does anyone know what I did wrong?
You most probably have a problem with the way you set the waypoints.If you follow the wizard of the UR pallet function you should be fine.
