A communication failure may happen if you have a cable damage for example.To troubleshoot such issue, it is possible to monitor to gripper communication in a thread to check any communication issues.The attached check gripper connection.script script includes the function checkGripperConnection() which will return True if any gripper is communicating and False if not.In some cases a power cycle may be necessary to recover gripper communication. The function rq_cycle_tool_voltage_until_connection() of the script rq_cycle_tool_voltage_until_connection.script can be use to do that.
