Hello @jdcnc
Yes it is possible. It will depends on your application. Robot and cobot could apply a force to polish those applications.
I invite you to look at our website to see our Sanding kit.
We have the Sanding kit that we provide which comes with the tooling but also the software to ease the programming. We can then create a path easily and apply a constant force on this path.
In most case, if the human can do the job, the cobot will be able to apply enough force too.
Hope this helped. I would love to learn more about your application. If you want to share more, I suggest you to write an email to coach@robotiq.com with a description and maybe a video of the manual process. It will create a support ticket and we will be able to help and see if it could be a good fit or not.
Best regards.
MarcAntoine_Gauthier
Hi. I'm curious if there is a robot arm that can be used to buff and polish small stainless steel objects. I'm currently doing this by hand.
How much pressure can these robot arms withstand?
Thanks
