You will need to enable remote control mode under settings and then choose remote control on the home screen of the pendant up in the upper right area. You should either see manual or auto mode, click on it and you can go to remote mode. If you have assigned a password you will need to go to auto mode before you can go to remote control
I have been searching for a while now but cant find a solution that works.
I would like to load and start a program on a UR10e from my python TCP/IP server application.
Sending a popup command, like popup("Hello World"), works fine.
But I need to have the polyscope in Remote control and so I need to start the program remotely.
I am using port 30002 and polyscope version 5.7.0
Bert-Jan
