Nicolas_Lauzier
We are proud to announce that we have built a palletizing solution with the end user, yourself, in mind: the Robotiq Palletizing Solution.
Our solution is perfect if you are looking for a solution that:
  • Can be set-up and reset-up quickly;
  • Can easily be set up directly on the robot teach pendant. Our solution doesn’t need an external PC;
  • Is already connected: the connection between the robot controller and the 7th axis or box sensor is already done;
  • Has a high performance cycle time;
  • Can pick a wide range of boxes and cover extensive heights and pallet dimensions;
  • Has a small footprint.
Furthermore, because safety is crucial, we have built an environment for safe integrations. Our system can be integrated with 3rd party safety sensors (not included). Please note that the customer is responsible for the safety in the implementation and the risk assessment.
For more information on the Robotiq Palletizing Solution, please visit our website. You will find all the specifications needed such as box weight, box dimensions, pallet dimensions and throughput.
Still not sure our solution is for you? You can easily validate if your product fits with the Configurator.
All you need are:
  1. Box dimensions
  2. Pallet dimensions
  3. Pallet pattern
Upon entering this information, you will find out if your boxes, pallets, and patterns match within the solution’s limits. If they do, the configurator will give you key indicators related to your application, such as how many boxes per minute can be palletized.
The Configurator can be found here
Hope this new solution has convinced you!
Don’t hesitate to contact us should you have any questions on this new application.
