Hello everybody,im trying to do a circle move with a UR3 but it doesn’t work.. I don’t understand the error.can someone help me please ?
@haneulines Unfortunately I don't speak French and google translate didn't help me. Attached is an example of a circle move similar to what I think you are attempting. I've seen joint limits and other general out of range errors when trying these. I did this on a UR5 virtual machine simulator.
I believe the error translates to the path is not reachable. With a UR3 there is limited range, if you can provide the pose of the center point it would be helpful
Bonjour,A priori le robot n'arrive pas à atteindre le premier point de votre cercle.êtes vous sûr que votre point centre est exprimé en coordonnées cartésiennes (X,Y,Z,Rx,Ry,Rz) et pas en coordonnées articulaires (valeur axe par axe)?Vous commencez par un déplacementP depuis un point de passage, avez-vous tentez de faire un déplacementA vers vos 4 points pour vérifier qu'ils soient accessibles?
@matthewd92 Hello,Attached the pose of the center point.Maybe the problem is the function that I used for Movej ?s t
@jelms I tried your program but it still doesn’t work... I think the problème here is the pose of the center but I don’t know why.
I tried @jelms 's program and it worked ! .Program Robot Program r≔45 r≔r/1000 var_1≔p[0.2,0.2,0,0,3.14,0] var_2≔pose_add(var_1,p[r,0,0,0,0,0]) var_3≔pose_add(var_1,p[0,r,0,0,0,0]) var_4≔pose_add(var_1,p[-r,0,0,0,0,0]) var_5≔pose_add(var_1,p[0,-r,0,0,0,0]) MoveJ var_5 MoveP var_5 CircleMove var_2 var_3 CircleMove var_4 var_5 My program works only with the MoveJ point (in bold).Whitout it I had lots of error messages and I still don't know why..Before, I was recording the position of the TCP manually, by using the freedrive command.And then I tried to save the position by entering X Y Z RX RY RZ in the parameters of the TCP and it worked.
