Hello, I tried looking for similar questions but unfortunately couldn't find a solution to my problem. I am running a TCP Socket server using C# Socket, and I am trying to this script of the UR10e : ori_connection = socket_open("192.168.0.3", 7777, "orientation")sleep(0.100)if(not ori_connection): textmsg("Could not establish a connection to 192.168.0.3:7777") error = Trueendori_message = socket_send_line("GetORI", "orientation")sleep(1)if(not ori_message): textmsg("Could not send GetORI to 192.168.0.3:7777") error = Trueendori_correction = socket_read_line("orientation", 10)textmsg("Got this: ",ori_connection)I do receive from ori_correction => True, after 10s I get a timeout error. From the server : => I save each connection once receiving a valid command I send to the client as follows : Client.Send(StringValueToByteArray(StringToHex("HI" + Environment.NewLine)))I used SocketTest to test the communication, and it worked just fine, so I am lost on where the problem is. I would appreciate your help. Thanks, Best Regards
sleep(0.100)
error = True
end
sleep(1)
error = True
end
From the server :
