dear I'm programming an UR5. To be able to make the program I have to work with rise/fall time.But I can't reach it.How can I work with rise/fall time?thank you very much
By the sensorsso that the cobot only looks at an emerging signal or a declining signal. do you understand what I mean?
In the code all you need to do is wait for either a signal to go high (rising edge) or go low(falling edge). You can do this within Polyscope using the wait command or in script using a while loop. With the whole loop you would loop while the negative condition was true so if I want to catch the rising edge of an input I could do this:while not get_standard_digital_in(0): sync() endThat would keep syncing so long as the digital input 0 were low, as soon as it rose it would exit the while loop and execute the next command. Is this what you are looking for?
