It can, just zero the ft sensor before you pick up the part, back out of the machine and stop to measure, just remember to wait a second or two for motion to stabilize then record the forces on the sensor. You can them compare the same motion with an empty gripper and a part and you can set a threshold that it needs to be over to know you have the part.
We are pulling a tube out of a machine and I would like to make sure we actually removed the tube before restarting the machine in case gripper drops the part. We have the RobotIQ F-85 gripper and the part weights 0.65kg I've tried using the rq_is_object_detected() but it is unreliable and alarms out frequently when the gripper is still holding the part. I issue the rq_close_and_wait() then immediately after check the status of rq_is_object_detected(). So I thought perhaps I could check the payload weight? I've searched the forums but I cannot find an example of this. Can it be done? Thanks!
