Simplest way is to create an installation variable and write to that. It’s automatically persisted by UR so even on power down it’s not lost.
Hello Matthew, Thanks for the direction! I'm off to google what an Installation Variable is
That worked perfectly thanks Matthew
Hello All,
Thank you so much for this forum! Would like to keep track of total parts the robot has processed even if robot gets turned off. Is there anyway to write a value somewhere that can be updated by the program & re-read at startup?. i.e. if it has processed 100 parts and gets turned off part count would restart at 100 and not zero? Thanks for all advice.
