@Ryan_Weaver you guys have had such an application in the past, right? How did you manage to use the gripper in an ESD sensitive application?
@Grady_Turner Anything on your side to make the gripper ESD Safe?
Manipulating PCB with our grippers
Our grippers are grounded through the robot ground and the fingertips are isolated from the rest of the gripper. So if your workstation, boards and robot (which it is initially) is uncharged, there shouldn't be any problem for manipulating PCB.
ESD Control Standards
We have the CAD models and measurements to be able to design your own fingertip s. According to the standard, you would simply need to ground the fingertip through the specified resistance (typically 1 megaOhm) using an external cable.
From the EOS/ESD Association website, you can find more info on how to avoid any risk related to ESD.
Here are the six basic principles of static control:
- Design in protection
- Define the level of control needed in your environment
- Identify and define the electrostatic protected areas (EPA)
- Reduce electrostatic charge generation
- Dissipate and neutralize
- Protect products
Anyone using our gripper to manipulate PCB?Feel free to share your experiences.
