Hi Vlastimil, I am looking to do the same, did you find a solution by any chance?
Hi sophvk, I was not able to find the license either in the virtual environment but I noticed that I can nevertheless access the routines from the CoPilot URCaps in the virtual env., which makes it possible to prepare the program offline. This covered my needs at that moment.sophvk said:I am trying to do the same, were you able to do it?
Hi, in URSim I have problem with URCaps in installation Tab: "Force Copilot Not licenced" - In a virtual machine I normally see a license key.
I have not save changes in program. Is there any procedure to set up a USB stick in VM?
Thank you, Vlastimil.
