Some time ago I worked with Keyence camera, below you can see implementations using Keyence scripts, a common problem was in case of more cameras that there was a school mistake in IP addresses, ports or symbolic name of the camera - otherwise everything worked perfectly,
Vlastimil
Has anyone used this controller with a UR5? I am able to get the UR and the controller to talk and i am able to use the robot operation screen on the Keyence controller but when it comes to actually run a program, a popup on the pendant says that there is a communications error. i am using a Sample program that Keyence provided me and with being fairly new at the Script programming im not sure why it is giving me that error. Thanks in advanced
