can anyone help with destacking from within a pallet sequence. I am using a magnetic gripper. Ive heard I can’t use Seek and have to use Find Surfacethanks
Maybe you could have a look to this post:https://dof.robotiq.com/discussion/comment/4584#Comment_4584Please share if you have any precise questions.
Here is what we just did to our customer's robot cell. This is palletizing example so you have to think a bit differently.Don't mind the yellow nodes, I didn't have a Copilot license in virtual Polyscope. The apply contact offset is used for relocating the pallet after it has been changed to empty one by operator. I think you can just ignore that node.Basically we just inserted Find Surface node inside palletizing template to find the surface of a pallet. When surface is found robot retracts 1 mm to open the grippers safely for dropping the part.In your case you could just use Find Surface node as below but instead of retracting 1 mm you just set your magnet gripper ON to grip the part. I hope this helps you.Maybe you could use this to make
thanks
