I found an article about servo control on the web:
https://learn.sparkfun.com/tutorials/hobby-servo-tutorial/all
Voltage is 5.5 VDC and UR is 24V.
Maybe you could use an analog output and try to make a program to generate the PWM pulse ?
Thank you for the reply! I had considered trying that, I will have to look into the capabilities of the analog output further.
I found another thread (https://dof.robotiq.com/discussion/comment/5479#Comment_5479) where you commented on using an actuator controller that can accept a 4-20 mA control signal. I am still hoping to find a hardware controller that will work for servos. I could use an Arduino to process a signal from the robot and send this to a servo controller but that doesn't seem like an elegant solution.
The post https://dof.robotiq.com/discussion/comment/5479#Comment_5479 is not related. It was a specific request.
You could use a rasberry pi with a hat to control the servolike this one:
https://www.adafruit.com/product/2327
Then you can make on the raspberry pi a python program which control the servo. It could interface with the robot using Ethernet connection.
I am working on a project that requires an actuator or solenoid to operate a small device. Due to cost, I would rather use a hobby (Radio Contol) grade servo, as an industrial actuator would be overkill for this application. The problem is I am totally stumped on how to control the servo using an output from the UR5. I found a topic on this forum that references using an Actuonix control board and actuator, which is close but not quite what I was looking for.
My understanding is that RC servos use a PWM signal between 1.0 to 2.0 microseconds to set the servo position. I am looking for way to achieve this with the UR5, whether it can do it directly, or if an external servo control circuit is required.
Any ideas?
