Hi,I have a Kassow KR810 and KR1205 with the new end of arm tooling plug allowing for IO at the end of the robot arm menaing we no longer need to run a cable down the outside of the cobot. however I do not have a cable from my current tooling plat that fits into the Kassows IO plug, can you advise me on what plate I need for this?
If you wish to connect Robotiq product at the wrist you may need to custom your connection. We have coupling with M8 or M12 connector.The pin out of out connectors maybe different from your robot.
