You may want to open or close gripper while moving the robot. With the current gripper TM component you don t have the possibility to do it but I would like to share with you an alternative solution.Using the modbusRTU communication system of TM it is possible to send gripper command in a thread.Here below is the main program:Gripper settings and activationMove the robot to point 2Gripper openRobot wait 3sThe variable which trigger the gripper close thread is witched to TrueThe robot is moved to point 3Here below is the thread:Check the statue of the variable which trigger the gripper close. If False wait 0.5s and loop.If true send a modbusRTU command to close the gripperThe modbus RTU command is the following:The variable sent is: var_sendCommand={0x09,0x00,0x00,0xFF,0xFF,0xFF}var_sendCommand[0]: Action requestvar_sendCommand[0]: Reservedvar_sendCommand[0]: Reservedvar_sendCommand[0]: Position requestvar_sendCommand[0]: Speedvar_sendCommand[0]: ForceCheck gripper manual for details about registers.Don t forget that you need to define the modbusRTU device in the left panel:The program is attached to this post.
- var_sendCommand[0]: Action request
- var_sendCommand[0]: Reserved
- var_sendCommand[0]: Position request
- var_sendCommand[0]: Speed
- var_sendCommand[0]: Force
