@jbahner
Do you have some numbers you can put on this?
Alexandre_Pare
Alexandre_Pare
@jbahner
What is the actual force control resolution and repeatability that you can achieve with the UR force mode? Knowing that I can't use an external signal for the force mode, what if I use an external force sensor? Is it complicated to do?
