Some time you may want to rotate the last joint of your UR robot at constant speed of your UR robot.You can do that using the script function: speedjHere below is an extract of UR scrit manual:Here below is an example of program with make nearly 1.75 turns of last joint:MoveJ Waypoint 1Script: speedj([0,0,0,0,0,3.14],25,3.5)Script : stopj(20)
MoveJ
Waypoint 1
Script : stopj(20)
