Is your UR5 connected to the PLC via Ethernet/IP or Profinet? If so, the PLC can monitor the position of the robot in real-time, you could just create the plane in the PLC and not have to send it.
Also, did you make the feature you are trying to use as a safety plane a variable? There is a checkbox on the feature on the installation tab.
Hi @matthewd92
i created a plane in UR5 cb series, i would like to send a boolean value once the robot move beyond my line to PLC.
I created a plane called Safe_Zone
I created a thread
But when i try to use the plane as a variable or pose, it got some error.
Can you please help me on that. Is there any other method
Thanks
Prasanna.V
