A work around sorta. The loop runs off a integer < 2, inside is a boolean that gets reset to false before insert node, if insert fails it gets set to true and the integer gets incremented, if the insert does not error the boolean stays false and sets integer to 2 which exits loop.
I am trying to loop the insert node until it successful completes the insert, using the UR eSeries. Right now I track when the insert node errors and keep track of how many times it errors but I do not have a way of exiting the loop when the insert reaches it target position. Any ideas?
Thanks
