Hello, AllI am trying to send script command to UR from my C# program.I am able to open a port, get connected and send script command to robot to move it, but it works point to point only.how can I send series of points and make it move continuously without hiccups?Thank you
You would need to compile it as a script program and send the entire program to the robot, then it would execute the program instead of a single line of code. There are some resources on the UR support site regarding how to do this.
Thank you for your Answer!can you direct me to the UR support page you mentioned above?Thank you so much!
Hello, All
Thank you
