is it possible that i can get the position of my tcp from a plane.
David_Gouffe
Yes, it is possible.
You need to get the current TCP position with the Universal-Robot command: get_actual_tcp_pose()
You then need to make a formula to calculate the distance from the defined plane to the coordinate retrieved.
-As we do not know how you define the plane, we cannot go deeper in the suggestions.
Enjoy math, UR and Robotiq product use.
David Gouffé
Integration Coach
Coach en intégration
