Here is how to update your gripper firmware to use grippers with our I/O Coupling.Required firmware versions:2-F Adaptive Gripper: GC3-1.6.8Hand-E Adaptive Gripper: GD1-1.3.16Vacuum Grippers (AirPick, EPick): GUV1-1.0.5Before proceeding with the update, follow these steps:Connect the standard coupling (with cable) to a computer USB port.Download the Upgrader file from one of the relevant links below.2F-GripperHand-E GripperVacuum GrippersRun the Upgrader, and update your gripper firmware.You gripper is now updated and is compatible with the I/O coupling. For more details, refer to your gripper instruction manual.Enjoy your new cable-free gripper on your UR CB Series cobot!
- Connect the standard coupling (with cable) to a computer USB port.
- Download the Upgrader file from one of the relevant links below.
- Run the Upgrader, and update your gripper firmware.
You gripper is now updated and is compatible with the I/O coupling. For more details, refer to your gripper instruction manual.2F-Gripper
Hand-E Gripper
Vacuum Grippers
