Hi @peter
Could you tell us more about your application?
Do you plan to have the robot holding the polishing tool or the part to be polished?
The force control node allows to apply a force in a specific direction and can be used with the path recording, multipoint path or path generator depending on your application.
If you could provide pictures or videos of your application, we'll be able to recommend the best way to do it
David_Gariepy
MarcAntoine_Gauthier
Does anyone have example of programming complex path, such as in ring polishing application?
I want to know how to program using 'Force control' by force torque sensor, path function and which relevant.
Thank you.
