We had two robots in a cell, one was picking parts from a vibratory feeder table and placing in a chute, the second was using vision to find a hole in the part and then place them onto the tooling.
The robot picking them from the table averaged a 3 second pick to pick, the robot placing the parts averaged 3.2 seconds place to place.
We have a cell feeding a punch press, we run just under 5 seconds cycle time (get part from feeder, load die, pull pressed part out and place on outbound conveyor) and the press has a 800-1000 ms cycle time so we run somewhere between 5.6 to 5.8 seconds per part, 20+ hours per day.
We have a number of cells that run in the 6-11 second range per part. One of them that processes 4 parts every 42 seconds has produced parts for 23.9 hours in a single day. It generally puts in 140-150 hours a week, usually only going down when the injection mold is not running. I’m that time it picks the part up, uses a labeling machine to accurately apply a label and packages the part for shipment to the OEM.
These are just just a few examples of cells we have at customer sites.
Erik_Cornelsen
hi all,
What are the fastest cycle times you have seen in collaborative robotics applications?
Is it possible to achieve for example a cycle in the order of few seconds?
Thanks,
Erik
