Dear Mr @matthewd92,Case-1:From third-party software am sending co-ordinates to ur3e, in that when am converting Rz value from degree to radian, am getting an error value. For both +180 or -180, the conversion results are -3.14. This happens only for 180 degrees.Case-2:I tried to move rz manually, but the directions are confusing.
Am just sending the values like 180 or -180in the UR program, i did convert using d2rBut for both Positive and Negative The value d2r value is -3.14.
What version of Polyscope are you using? I just ran a test on Polyscope 3.8 and the signs are correct +180 -> +3.14, -180 -> -3.14
Case-1:
Case-2:
