The brief answer is Yes, it is possible.
You need to call the Spiral Search using a script function replacing the target position by the predefined variable position.
I will build an example and come back to you with it.
Regards,
Integration Coach
Coach en intégration
Robotiq is now into packaging, palletizing and sanding applications. Learn more about our new Vacuum Grippers and the Robotiq Sanding Kit.
1-888-ROBOTIQ #275 (762-6847)
1-418-655-9221 (Cell)
Follow us on
Visit us:
David_Gouffe
Hi Guys,
We have an UR10 e-series with the force pilot installed. Is it possible to use the spiral search command but instead of using teach target position, to use a predefined variable position?
Thanks
