Robot Program
MoveJ
home
MoveL
Waypoint_15
Waypoint_16
Waypoint_17
MoveJ
Waypoint_1
Gripper Close (1)
Set DO[0]=On
Set DO[0]=Off
MoveL
Waypoint_2
MoveL
Waypoint_3
MoveJ
Waypoint_4
Waypoint_12
Waypoint_13
MoveL
Pressing_button
Release_button
MoveJ
Waypoint_7
Waypoint_8
Waypoint_9
Waypoint_10
Waypoint_11
Waypoint_14
Pallet
Pattern: Square
Corner1_1
Corner2_1
Corner3_1
Corner4_1
PalletSequence
If (cnt_1%2) == 0
Approach_1
PatternPoint_1
Gripper Move50%
Exit_1
Else(cnt_1%2) == 0
Approach_2
PatternPoint_1
Gripper Move50%
Exit_1
MoveJ
Waypoint_18
Waypoint_19
Nicholas_Francoeur
@ctiger, would you share the .urp file?
Robot Program
MoveJ
home
MoveL
Waypoint_15
Waypoint_16
Waypoint_17
MoveJ
Waypoint_1
Gripper Close (1)
Set DO[0]=On
Set DO[0]=Off
MoveL
Waypoint_2
MoveL
Waypoint_3
MoveJ
Waypoint_4
Waypoint_12
Waypoint_13
MoveL
Pressing_button
Release_button
MoveJ
Waypoint_7
Waypoint_8
Waypoint_9
Waypoint_10
Waypoint_11
Waypoint_14
Pallet
Pattern: Square
Corner1_1
Corner2_1
Corner3_1
Corner4_1
PalletSequence
If (cnt_1%2) == 0
Approach_1
PatternPoint_1
Gripper Move50%
Exit_1
Else(cnt_1%2) == 0
Approach_2
PatternPoint_1
Gripper Move50%
Exit_1
MoveJ
Waypoint_18
Waypoint_19
Hi @Nicholas_Francoeur,
Not sure what I have done wrong. I bring out the if statement from the palletsequence tree, and tried running the program, I still having the issue of not going into the next column under the approach line. After the approach line it goes back to corner 1 instead of working towards corner 2. I am currently using PolyScope 5.1, would that be the issue? I have tried running the pallet_180deg.urp program and the behavior is the same as what I am facing.
Thanks in advance.
Nicholas_Francoeur
@ctiger, Can you try reteaching you corner waypoints? Have them above your wooden box. Then have the approach point below them.
Thank you
Nicholas_Francoeur
@ctiger, let us know how it goes!
Nicholas_Francoeur
@ctiger, have a look at the UR software manual here.
A relative waypoint would be:
A waypoint with the position given relative to the robot arm’s previous position, such as “two
centimeters to the left”. The relative position is defined as the difference between the two given
positions (left to right).
Note: repeated relative positions can move the robot arm out of its workspace.
The distance here is the Cartesian distance between the TCP in the two positions. The angle
states how much the TCP orientation changes between the two positions. More precisely, the
length of the rotation vector describing the change in orientation.
In your case for the IF statement:
Hope that helps!
