Hello @Sebastian
Did you set the payload properly in the TCP setting?
I tested it here and it's work fine as long as there is no force applied on the tool. However, once you apply a force and release it, the behavior is not what I expected as it starts moving in the opposite direction.
The force mode of the CB series isn't precise enough to handle such low forces.
I would recommend adding a Robotiq FT 300 to get a better force control using Force Copilot software
Best regards
David_Gariepy
Hey there,
I ran into a problem in regards to the force_mode at my work. I have a UR3 (Polyscope 3.5) and a UR5 (Polyscope 3.9) and the issue happens for both of them. When I start the force_mode with 0 N applied, the robots are starting to move in the positive direction of the compliant axis. I was expecting there wouldn't be any movement with 0 N. When I apply a force of -100 N, for example, he first moves forwards, then stops and moves back, as expected for -100 N. Does somebody know why this is happening?
Best regards
Sebastian
