I would also like to know if there's a way to do this.
We are using freedrive to set waypoints for different stations for a pick-and-place application, but how to precisely align the gripper parallel or perpendicular to an axis? Or maybe align a wrist joint to an axis?
It's probably a simple question, but I can't figure it out.
I'm trying to set up the robot whereby an operator manually moves the robot TCP to a position and sets it as waypoint_1.
Then the program automatically orients the TCP so it is parallel to the base X and Y axis.
My thinking is that I can use the following code:
Pos1 = get_actual_tcp_pose() #records the current position to Pos1
Pos1[4] = rotation needed to get parallel to Base X
Pos1[5] = rotation needed to get parallel to Base Y.
And then a MoveL to Pos1 brings the TCP into line.
Firstly I can't see a way to access elements in the array like this, and secondly, I don't know if it's the best approach.
If anyone can tell me what I'm missing here I'd greatly appreciate it.
