Hi @aluu
Could you please share a picture of your force control setup?
Did you try to use a lower stiffness to see if it changes the behavior?
Hi @David_GariepyDavid_Gariepy said:Hi @aluu
I have attached a screenshot of the setup.
I have tried it with 50 and 0% stiffness, but it hasn't changed the behaviour. The force control is under a find surface node which is set to a force threshold of 1.5N as well in the Z+ direction and this works fine.
I am also wondering, when I define the multipoint path, should the waypoints already be on the surface?
David_Gariepy
I am using the teach pendent on a UR10 trying to implement a multipoint path with the force control node on a UR10, however am not having much success. I am able generate a multipoint path however it does not use the force control that I've set.
I am using the FT300 and have the Force Copilot URCap (UCS-1.8.0 for PolyScope 5.1.2+).
Any help on this would be greatly appreciated. Thanks!
