I have used the Allen-Bradley utility to import the eds file found at the same link. I have tried creating an eds from scratch using the Allen-Bradley utility. I have also triple-checked all the EIP
parameters in the UR EIP module in the Allen-Bradley programs and have
everything set as recommended by Universal. No matter what I have done, I
have never been able to get the PLC to recognize the robot.
I can't get the PLC to see a UR5 over EIP. I can ping the robot successfully with my PC connected to one ethernet port on the processor and the robot on the other port of the processor. I have replaced all the cables.
I am using RSLogix 5000 v30.01 and Allen-Bradley 1769-L24ER-QB1B. The robot is a UR5 running 3.6.1.30595.
I have tried with the two Logix5000 programs from UR’s webpage:
https://www.universal-robots.com/how-tos-and-faqs/how-to/ur-how-tos/ethernet-ip-guide-18712/
I have used the Allen-Bradley utility to import the eds file found at the same link. I have tried creating an eds from scratch using the Allen-Bradley utility. I have also triple-checked all the EIP parameters in the UR EIP module in the Allen-Bradley programs and have everything set as recommended by Universal. No matter what I have done, I have never been able to get the PLC to recognize the robot.
Thanks in advance for any advice!
