Hello @BenjaminK, The Robotiq 3-Finger gripper has an EtherCAT option. For the 2-Finger gripper or the Hand-E gripper, an EtherCAT - Modbus RTU gateway is required. The Robotiq Universal Controller is perfect for that purpose. As for the mechanical installation, we have a few different adapter plates and couplings available, including a blank one. If you tell me the bolt pattern of the flange of your robot, I could tell you if we have an appropriate coupling for it.
David_Levasseur
@BenjaminK, For any Robotiq 2-finger gripper on a robot different than UR, you should order everything separately:
- Gripper: 2F-85 (AGC-GRP-2F85), 2F-140 (AGC-UR-KIT-140), Hand-E (HND-GRP)
- Appropriate coupling (AGC-CPL-063-002)
- 10 meter cable (CBL-COM-2065-10-HF)
- EtherCAT controller (UNI-CTR-001-ECAT)
BenjaminK
A customer asked the possibility of gripper using with Denso Robot. I said, basically 'YES' but came back here to get your confirmation.
The communication interface of their Denso Robot is EtherCAT. But I'm not sure it works or not if they add the EtherCAT fieldbus option on gripper.
Besides, should they make a specific gripper coupling for Denso Robot?
What do you think?
