Hi All,I am using UR 10e series. I would like to know how do I give a simulated conveyor tracking to the UR without the inputs of conveyor belt? I would like to learn how it would run in a linear tracking, but the Polyscope asking for Modbus. How do I bypass the Modbus and have the UR running on its own?Thanks in advance.
@ctiger With the UR script function set_conveyor_tick_count(), you can simulate the conveyor motion. In a parallel thread, you can define the conveyor actual position and motion by updating the tick count continuously.
@ctiger If I'm right, at 1000 tick per meter, if you increase the actual tick count by 1 every second, the robot position will be offset in the conveyor direction at 1 mm/s. At 10 000 tick per meter, an increase of the tick count by 1 every second, the robot position will be offset at a rate of 0.1 mm/s.
Hi All,
Thanks in advance.
